Gpz1100 a2 engine breaking
James
#1 PostAuthor: James » Sun Jan 28, 2024 4:17 pm
Gpz1100 a2 head,all fins and studs in good condition.it will need a repair at one of the cam bolt threads as it ls damaged please see photo.all parts of the engine available.£200.00 ph 07443589994 if interested.
neilbarrett
Re: Gpz1100 a2 engine breaking
#2 PostAuthor: neilbarrett » Mon Jan 29, 2024 1:05 pm
Were abouts you based?
James
#3 PostAuthor: James » Mon Jan 29, 2024 5:23 pm
N.ireland
#4 PostAuthor: Z1streetfighter71 » Sat Mar 30, 2024 3:35 pm
What number range is the engine if you still have it James.
James
#5 PostAuthor: James » Sat Mar 30, 2024 8:47 pm
Still have crank cases,if any good to you.
#6 PostAuthor: Z1streetfighter71 » Sat Mar 30, 2024 9:28 pm
James wrote:Still have crank cases,if any good to you.
what numbers are they in? im looking for after 21000 and 24000 max...
James
#7 PostAuthor: James » Sat Mar 30, 2024 9:53 pm
I will check in morn.cheers
#8 PostAuthor: Z1streetfighter71 » Sat Mar 30, 2024 9:54 pm
James wrote:I will check in morn.cheers
Thanks James, appreciated
#9 PostAuthor: Z1streetfighter71 » Sat Mar 30, 2024 9:56 pm
And if there are any bits left like body work and electrical let me know, might make a trip up.
James
#10 PostAuthor: James » Sat Mar 30, 2024 10:05 pm
I have the frame no v5 but have reg no.
James
#11 PostAuthor: James » Sat Mar 30, 2024 10:09 pm
My no is 07443589994
#12 PostAuthor: Z1streetfighter71 » Mon Apr 01, 2024 8:57 am
James wrote:My no is 07443589994
Thanks for that James but the number range is a bit far out for the bike, i have a bead on a 25,000 set, that puts them right above the number range but fairly close.
Return to “For Sale”
