I am looking for a rear wheel Drum for a 1976 Z900 a4
If you have one for sale please let me know.
I wanted to fit Sisc rear but am told it won’t fit.
Z900 rear wheel or Hub (Drum Brakes)
Re: Z900 rear wheel or Hub (Drum Brakes)
Can’t see why it wouldn’t fit. But it’s not the correct rear brake for a Z900A4 Drum brake is correct fitment. I prefer the drum brake, as the standard disc drake is pretty much useless.
Have you got the correct swing-arm.
Torque Arm connection bracket for Disc brake is on the top of Swing-arm. Drum has torque arm connection bracket on the underside.
Sorry haven’t got a spare hub. Good luck
Thanks Adrian, I hope to get a hub soon, I’ve bought a front hub which I’ll have respoked, I only need the rear hub or wheel now.
I really don’t like the alloy wheels, I don’t think they do the bike any justice.
I was leaving my options open on the rear as a wire wheel with disc is better than the alloy wheel.
Did you get sorted ?
- new poster
got a pair of akront wheels sat in my garage twin disc on the front and drum rear of my a4 .
nice to be back in the z1 owners club once again
Is this sorted? I may have come across a Z1B one (to be confirmed by further research)
chrisNI wrote:Is this sorted? I may have come across a Z1B one (to be confirmed by further research)
Same reason I asked above I have got a Z1b one too.
- Z1streetfighter71
- ZedHead
Im looking for a 303 5D or close to it.
Thank you to those that helped me get a rear wheel.
ALL SORTED now thank you.
Regards Derrick
Regards Derrick
