Hi
I'm after the sleeve ( spacer ) between the sprocket bearing and the rear wheel bearing. Part No 42036-026 for a Z650 B 1977.
Cheers Glenn
Z650B rear sleeve, Hub couple. ( on rear axle)
- warren3200gt
Re: Z650B rear sleeve, Hub couple. ( on rear axle)
Google the part number, loads on ebay. Its a part used on many models of the era.
PUM 488 June 2023
Hi Warren I've looked on eBay, and there's only 2. one in Spain and 1 in Belgium. I'm in the UK. Unless I'm using E bay wrong, i did put in the part number
Hi All
A chap called Karl has given me all the dimensions, so I've made one on the lathe. It fits like a glove
Users browsing this forum: Google [Bot] and 28 guests
