zephyr rear wheel
NorfolkrobA2
zephyr rear wheel
#1 PostAuthor: NorfolkrobA2 » Sat Mar 23, 2024 9:26 am
hi everyone,im now fitting a zephyr 550 rear wheel into my 78 z1000 a2,everythings good until i came to the caliper side rear wheel spacer,just a tad too wide to accomadate the rear caliper and chain adjuster,so i have either to shave my spacer down to suit or does anyone know if another spacer does the job ?...
Andy M
Re: zephyr rear wheel
#2 PostAuthor: Andy M » Sat Mar 23, 2024 9:55 am
Interesting , any pics ?? You will probably need to shave the spacer or make up a new one. , obviously most important chain run, wheel central etc.
NorfolkrobA2
#3 PostAuthor: NorfolkrobA2 » Wed Mar 27, 2024 3:51 pm
so far.so good...550zephyr wheel on and looks awesome...took out bike to check,just up road....hmmm..slightly weird..discovered rear 550 spindle needs a spacer,caliper side,had to shave down right side spacer as wheel as it needs to be 13mm length,so now have to sort another spacer to be fitted between caliper and adjuster...must admit looks awesome with a 160 tyre on...more to come
#4 PostAuthor: Z1streetfighter71 » Wed Mar 27, 2024 9:33 pm
Is'nt the 550 supposed to have a 140 on it, is the tyre bowed in the middle?
moizeau
#5 PostAuthor: moizeau » Thu Mar 28, 2024 9:03 am
160 is the size for a Zeph11
NorfolkrobA2
#6 PostAuthor: NorfolkrobA2 » Fri Mar 29, 2024 9:00 am
well the wheel i bought came with the tyre on it....but it fits lovely,all im waiting for now is a spacer for the caliper side to take up the slack because of the different size spindle..
NorfolkrobA2
#7 PostAuthor: NorfolkrobA2 » Fri Mar 29, 2024 9:06 am
#8 PostAuthor: Z1streetfighter71 » Fri Mar 29, 2024 6:07 pm
Its not about if it fits lovely, you can shoehorn an oversized tyre on there easy enough but the side wall will be pinched and creates a dome effect where there should be a flat section. That effect means that the amount of Tyre on the road ( contact patch) is reduced drastically and the handling with it. This might be a cause of the Squirrely effect. Not saying not to run a 2 over size tyre but i wouldn't.
NorfolkrobA2
#9 PostAuthor: NorfolkrobA2 » Wed Apr 03, 2024 10:48 am
squirrly effect was due to me not fitting a spacer i have now had made and it fits superb....wheel is now finished and im happy..
