1000J/R carb parts
1000J/R carb parts
#1 PostAuthor: chrisNI » Sat May 04, 2024 9:40 pm
Has anyone a float pin 16032-008 they don’t need, and even better a left hand float bowl for the 1000R CVs one of mine has the drain screw jammed in and i don’t want to smash the bowl trying to remove it, as if I can’t get one it will at least still function. Doesn’t have to be black but even better if it is :shock: Float pin is weirdly a bit bent someone must have been in here before :shock: I know I can order a new pin but it’s embarrassing to ring z-Power with a £3 order…
:D
Skid Mark
Re: 1000J/R carb parts
#2 PostAuthor: Skid Mark » Sat May 04, 2024 10:18 pm
Chris,
I recently got a bank of black BS34’s due to an issue I had with no 3 carb. Pretty sure I have what you need.
Pm me when you get a chance
