Zrx temp & oil pressure lights
Both light have stopped coming on when the bike ignition is switched on. The did have a habit of flickering together at times so I'm suspecting a bad connection or short somewhere.
Re: Zrx temp & oil pressure lights
They're renowned for broken wires around the headstock due to the harness being tight when turning the handlebars, I'd start there first then check for any loose connections in the headlight bowl
Z1b,
zxr750 m2,
zrx1200
Z1000j lawson race bike,
Versys 1000gt (2019),
zxr750 m2,
zrx1200
Thanks. Randomly working again now. Will investigate. It on my ZRX not the Z1a there is no wiring in the headlight bowl.
jonhunt wrote:Thanks. Randomly working again now. Will investigate. It on my ZRX not the Z1a there is no wiring in the headlight bowl.
Sorry. Ment inside the fairing at back of headlight
Z1b,
zxr750 m2,
zrx1200
zxr750 m2,
zrx1200
