Boyer Brandsen Ignition
Obr
#1 PostAuthor: Obr » Mon Jun 02, 2008 5:43 pm
Do anybody know :?:
I mounted a Boyer ignition today, and calibrate ignition with a strobe. 1500rpm = 5deg. and 3000rpm = 40deg. running smooth idle at 1000rpm, but when doing a testride it missfire between 6000 and 8000 at full trottle. What's wrong?? The sparks do have the right colour so I don't think it's the carbs, do any of you have the same experience?
1976 Z900 - 1980 KZ1000 LTD - 1980 Z1 Classic - 2001 ZRX1200 R
Hello from Norway
Obr
#2 PostAuthor: Obr » Tue Jun 10, 2008 4:34 am
anyone help?
Hello from Norway
ash
#3 PostAuthor: ash » Tue Jun 10, 2008 7:22 am
Take it off and fit a Dyna, iv never got on with Boyer, sorry carnt help anymore than that,
Taffus
#4 PostAuthor: Taffus » Tue Jun 10, 2008 7:30 am
Check the advance mcganism with a timing light there is 1 mark for running at low revs, I think the advance should come at about 4k
debben1
#5 PostAuthor: debben1 » Tue Jun 10, 2008 11:24 am
I dont think the Boyer uses the auto advance unit, but Ash is right, fit the Dyna S, its far superior imho.
#6 PostAuthor: Rich » Tue Jun 10, 2008 7:20 pm
I had a Boyer on me Rickman, melted it at the top of Beely Moor, coasted down and sat at the pub all afternoon waiting for collection. :beer2
#7 PostAuthor: Pigford » Tue Jun 10, 2008 8:48 pm
Dyna S is good.... :twisted:
Dyna 2000 (programmable) not so clever ... :evil:
Sent my unit off end last week to Dynatek to await their test report :??
As I am an impatient runt, I ordered a Dyna S to get me Black Zed running and good old Z1Enterprises, it turned up today... super fast service as always... cheers Jeff & team :lol:
Ed Z1-R
#8 PostAuthor: Ed Z1-R » Tue Jun 10, 2008 10:50 pm
The chaps maybe right about the boyer ign.
Although i did not set mine up,(except a duff coil) ive had no problem with my BB unit. I guess should it go POP or im flush with cash i will go the Dyna route.
But until then :arrow:
z1000Chris
ignition
#9 PostAuthor: z1000Chris » Wed Jun 11, 2008 5:51 am
Assuming it was allright before you fitted the BB ignition, check all the connections, etc, both my Z's have had Boyer ignition on when I bought them so I have never been able to do a back to back comparison with any other make, the only thing is, I find the strobe bounces about alot when setting up the advance, but other than that it revs out ok. p.s try backing the ignition off a bit and try it then, good luck z1000 chris
fletch
#10 PostAuthor: fletch » Fri Jun 13, 2008 10:03 pm
Hi obr,
i have a bb ignition and had a few probs setting it up too,but phoned bb
direct and they talked me through the probs i was finding,that was six
years ago and it has never let me down since.give the guys a bell,they
are alway's polite and helpful.
Good luck.
Fletch.
Bikes will lead you into a life of grime....
jakeymara
Boyer
#11 PostAuthor: jakeymara » Sat Jun 14, 2008 12:03 am
I've religously stuck BB on all my old Brit bikes and it has worked perfectly no bother.
Strobing has had to be set up using a battery remote from the bike, as using it on the bike always set it up about 2 degrees retarded leading to ignition in the zorsts and overheating.
But my Kwak has Dyna S and I have to say it is absolutely spot on and reliable.
#12 PostAuthor: Pigford » Sat Jun 14, 2008 8:51 am
I think BB is used on loads of british iron, as thats one of the FEW choices.
BB is a bit fragile and as stated, not the best.
I now had another Dyna S on me Black Zed and it took literally 15 mins to set up and get going :wink:
I just had an email back from Dynatek about me Dyna 2000, and they are just waiting for it to arrive :P and said they'd get on it pronto. Must admit they have replied to all my emails and seem pretty helpful & keen - so far :wink:
For the ££££, get a Dyna S from Z1Enterprises, it'll be about £70 delivered, and you'll get it within a working week too :twisted:
eastlondon
boyer bransden ignition
#13 PostAuthor: eastlondon » Sat Jun 14, 2008 5:35 pm
You may be better off emailing Boyer as their telephone technical helpline is only available at specified times. You can get their email from their site. I sent an email to them last week re. which coils to use on my z900 with their micro digital sysyem and they replied within 4 hours.
Raf
HarrisTZ
#14 PostAuthor: HarrisTZ » Mon Jun 16, 2008 7:01 am
Which coils did they recommend?
eastlondon
#15 PostAuthor: eastlondon » Mon Jun 16, 2008 9:21 am
Here is the reply I received. It may be useful to other owners:
Re: Ignition Coils
Dear Sir, The Micro Digital systems are designed to run with contact breaker specification coils. This type of coil should have a resistance at the primary winding of about 4.5 Ohms.
These ignition units can be damaged if used with HT coils of less than 3.5 Ohms.
The instructions for this system (KIT00088) can be found at the website.
www.boyerbransden.com
