Z1000 swingarm
davidcouzens
Z1000 swingarm
#1 PostAuthor: davidcouzens » Fri Sep 06, 2024 9:59 am
Hi looking now for a standard z1000 a1 or a2 swing arm not bothered which also if anyone can confirm z1r swingarm might fit as the part number appears to be the same? Many thanks.
compo z1r
Re: Z1000 swingarm
#2 PostAuthor: compo z1r » Fri Sep 06, 2024 6:44 pm
z1000a1 part No 33001-091
z1000 a2 No 33001-1014
z1r No 33001-1014 so a1 is different to a2-z1r
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
davidcouzens
Re: Z1000 swingarm
#3 PostAuthor: davidcouzens » Fri Sep 06, 2024 6:51 pm
Hi thanks for the reply. I think that only the bearings are different between the a1 and a2? Which I believe won't cause me a problem to fit?
compo z1r
Re: Z1000 swingarm
#4 PostAuthor: compo z1r » Fri Sep 06, 2024 8:40 pm
davidcouzens wrote:Hi thanks for the reply. I think that only the bearings are different between the a1 and a2? Which I believe won't cause me a problem to fit?
z1r will drop straight in as will a lot of other swing arms ive one out now on my bench i can measure it for u i have a zrx 1100 that fits a z1000 frame
davidcouzens
Re: Z1000 swingarm
#5 PostAuthor: davidcouzens » Sat Sep 07, 2024 4:42 pm
All sorted now many thanks
