Looking for Front Right and Rear Right footrest rubbers for :-
Z1000 LTD 1981 (non kickstart model)
Z1000J
Z/KZ1000 CSR
Z1000R
Z1100R
I believe all the above bikes share the same foortests.
I dont need the bracket for the Front Right, just the rubber with the metal insert.
I do need the complete Rear Right with small mount bracket.
Rubbers must be undamaged and not too worn.
Please PM if you can help ?
Thank you
Footrests Wanted
Re: Footrests Wanted
Hi. Had a torn one on my B2 when acquired. Lots advertised by breakers in the UK are similar. I ended up getting an as new item from Germany at reasonable cost via Ebay, there's always some on there. There seems to be a surplus of older Z1000/1100 from there.
