GPZ1100 A2 Airbox to trottle body rubbers
Does anyone have , or know where I can get preferably genuine Rubbers for a 1100 unitrac? I have sourced 2, I would do with 2 more. Part no. 14073 1104?
Thanks in advance!
Thanks in advance!
Re: GPZ1100 A2 Airbox to trottle body rubbers
Top Man Al!
I can get around the postage thanks to 'Address Pal'.
It will be interesting to see how we will manage for parts going forward as more and more become NLA.
https://www.ebay.co.uk/itm/135163156795 ... ed,%20prep
maybe try throttle body rubbers rather than trottle in search
Thanks Rangeroy!
no problem & seller now offering at £19.99 so don't press buy it now
give it 12hrs
give it 12hrs
I manage to get one more, so I have three new rubbers,but advent managed to get a fourth, any suggestions. I don’t want to heat the best of the existing one but may have to. Any suggestions welcome
If you soak the rubbers in a mixture of wintergreen and rubbing alcohol overnight it softens the rubbers without damage,it stinks i bit though
stusco wrote:If you soak the rubbers in a mixture of wintergreen and rubbing alcohol overnight it softens the rubbers without damage,it stinks i bit though
What is wintergreen? I had heard that brake fluid will soften them but they harden pretty quickly once dry.
Its a muscle rub a bit like ralgex ,ill try and find the recipe i got it from muttsnutts on rdlc crazy
Mix wintergreen oil with Isopropyl Alcohol 50/50 soak the hard rubber for a couple of days and the go supple and stay that way but they smell like a rugby club dressed room
stusco wrote:Mix wintergreen oil with Isopropyl Alcohol 50/50 soak the hard rubber for a couple of days and the go supple and stay that way but they smell like a rugby club dressed room
Well I can live with the smell, since Covid my sense of smell is gone, and funnily enough my farts don’t smell anymore either!
Skid Mark wrote:I manage to get one more, so I have three new rubbers,but advent managed to get a fourth, any suggestions. I don’t want to heat the best of the existing one but may have to. Any suggestions welcome
I've got some if you're still looking for one. I've also used the wintergreen.........they stay supple for about 18 months then start to harden up again.
Hi zoos,
I just pm’d you!
I just pm’d you!
