Can anyone point me to a good supplier for O-Rings in my 1981 Z1000J CV Carbs?
I need the latest (viton?) type o-rings.
1). O-Rings for float valve buckets
2). O-Rings for the small push in plug that covers the idle/pilot jets
Thank you
Z1000J Carb O-Rings
Re: Z1000J Carb O-Rings
The float valve seats are the same as my Z1000R2 and I've used viton ones from simplybearings.co.uk . Off the top of my head I think they're 7mm x 1.5mm (ID x o-ring section). Less tha £5 for 10
I haven't replaced the pilot plug seal but it's the same measuring theory as above.
Thank you
