Debben built 18mm ZX1100 Unitrak or Z1100R1 crank which i had done about 8 years ago and still not needed as mine refuses to pop.
It was made from two cranks which i bought and he did the work / supplied the bearings and one part from another spare crank.
Brief was 'perfect race crank' no expense spared, but not lightened.
They were stripped, examined, cleaned, polished (not mirror) assembled, true'd, welded and balanced (not drilled).
Brown staining is Ambersil not rust and it has been sat under the radiator in the spare room since it was done.
It was over £1100 and i will swallow the VAT and ask £810 which was the labour and parts not including the two original cranks etc..
There is also a large box of good webs / bearings that can go with it if required.
Collection is fine or youre courier / insurance.
Wiseco 1170, 18mm High comp. piston kit brand new in box never fitted bought for crank change over see above.
This is the 1172 kit for ZX1100 Unitrak / Z1100R1 unused with clips, MLS head Gasket and with XG (new version) rings.
Currently retailing in the UK approaching £800 will take £650 for them as thats about what i paid 8 years ago.
Happy to have collected or youre courier / insurance at youre expense.
Crank and pistons (new other)
