Z1,Z900, z1000 A1/A2 Crankshaft
Mick J
#1 PostAuthor: Mick J » Tue Oct 08, 2024 7:41 pm
Looking for a very good crankshaft, anything with the small alternator nose would do, needs to be in excellent condition or rebuilt, welded too would be good. Just inspected my crank and there's some rust damage on the where the outer bearings run, so it's a no go. Please let me know if you have something, even it's a damaged crankshaft with good outer webs that I can use, I have an hydraulic press. Will pay decent money for a known good one. Thanks, Mick
Mick J
Re: Z1,Z900, z1000 A1/A2 Crankshaft
#2 PostAuthor: Mick J » Sun Feb 09, 2025 10:50 am
Still looking for a rust free crankshaft with minimal wear if anyone has anything, also the outer bushes or races with no pitting, anything useful, even damaged. I now have a supply of high quality German needle rollers to refurbish the outer crankshaft bearings if anyone is needing them. I can press out the old rollers and fit new rollers to your bearing cages. P.M me if interested, seems that the complete bearings are no longer available, unless anyone knows different?
Maunders
#3 PostAuthor: Maunders » Sun Feb 09, 2025 6:59 pm
Hi Mick,
Crank journal and big end bearings are available from Japan.webike.net Just type…..kawasaki z1 voice….and you should find them easily enough, but it gets a bit spendy though.
Connecting rod bearings are about £28 quid each and you will need 4.
Journal bearings are about £25 quid each and you will need 6.
By the time you add postage, given Rachel her customs duty and vat, it stings a bit.
Im sure you will find a suitable crank somewhere.
Mick J
#4 PostAuthor: Mick J » Mon Feb 10, 2025 7:21 pm
Thanks for the info, I don't need the big end or crank bearings as I removed the old bearing rollers and fitted new rollers into the cages, I mentioned this in case anyone else is looking to replace theirs. Still wanting a clean crankshaft or any good parts, thanks, Mick
thebuelligan
#5 PostAuthor: thebuelligan » Wed Mar 19, 2025 10:14 pm
Hi Mick
Might be able to help with the crank
rpeters
Bristol's "H" Hoarder
#6 PostAuthor: rpeters » Thu Mar 20, 2025 6:42 am
I am having a clear out of a lot of Z1R D1 bits and have a very good condition crank available. I believe its the same crank but stand to be corrected?
Rob
paid up member
#7 PostAuthor: Z1streetfighter71 » Thu Mar 20, 2025 8:15 am
rpeters wrote:I am having a clear out of a lot of Z1R D1 bits and have a very good condition crank available. I believe its the same crank but stand to be corrected?
Rob
D1 crank is the same its the D2 mk2 engine would be different and what this i hear about parts clear out.... :biggrin
rpeters
#8 PostAuthor: rpeters » Thu Mar 20, 2025 8:55 am
yea thought so!....
lot of prts but dont want to break the rules as no photos but briefly (soz admins)
discs
carbs
pistons
new barrels
covers
+ more
paid up member
#9 PostAuthor: Z1streetfighter71 » Thu Mar 20, 2025 12:00 pm
rpeters wrote:yea thought so!....
discs
carbs
pistons
new barrels
covers
+ more
Ill keep any eye out for the for sale post!
Mick J
#10 PostAuthor: Mick J » Fri Mar 21, 2025 9:22 pm
Hi Rob, is a Z1r crankshaft the same as a Z1 crankshaft, or same as Z1000A1? The reason I ask is, I have a Z1 crankshaft, which I haven't pulled apart yet and was hoping to find another the same so I can build one good one out of the two. I am interested though, cheers, Mick
#11 PostAuthor: Z1streetfighter71 » Fri Mar 21, 2025 10:00 pm
Mick J wrote:Hi Rob, is a Z1r crankshaft the same as a Z1 crankshaft, or same as Z1000A1? The reason I ask is, I have a Z1 crankshaft, which I haven't pulled apart yet and was hoping to find another the same so I can build one good one out of the two. I am interested though, cheers, Mick
The Z1000 and Z1r are the same, the Z1 is different (lighter).
#12 PostAuthor: Z1streetfighter71 » Fri Mar 21, 2025 10:03 pm
Z1000 left an Z1 right.
#13 PostAuthor: Z1streetfighter71 » Sun Mar 23, 2025 8:41 am
Fairly small money in the States. $35 bucks right now. Shipping might be a thing.. US $246 About £220 all in bar yer duty.
