Z1000 R2 Elr swing arm
Stugill
#1 PostAuthor: Stugill » Wed Oct 09, 2024 10:44 am
Good morning all.
I've got the swing arm off as i'm changing the chain and sprockets, as the swingarm is looking a bit rough i'm considering getting it repainted etc and this has led onto looking into; the needle bearing, sleeve and grease seal.
The manual mentions specific pulling tools and a driver to replace?
Are there any methods to remove and then replace them?
Stu
Skid Mark
Re: Z1000 R2 Elr swing arm
#2 PostAuthor: Skid Mark » Wed Oct 09, 2024 11:06 am
I used a parallel punch to remove and carefully replaced with a block of timber and light taps. If it needs to be sunk below the surface of the sleeve on the pivot use a socket that is just the right size. you might not need to use the socket if the timber Goldie Locks! not too hard but not too soft!
Stugill
#3 PostAuthor: Stugill » Wed Oct 09, 2024 3:25 pm
Mark.
Thanks for that, did you just remove the seals and then knock it through, and out one end?
Stu
Skid Mark
#4 PostAuthor: Skid Mark » Wed Oct 09, 2024 6:51 pm
From memory ( it was during Covid) I am starting to doubt myself! Nothing new there!
I think I didn’t have a punch long enough, so I put a nut,washer and nut on a bit of treaded bar and put the washer through the pivot til it caught on the lip and then bet nine shades of shite out of it. I think I had to grind down the washer to fit in and left it a little Eliptical. Hope I’m explaining it clearly. The caps just lift or pop out the seals I routed out with a pick AFAIR. They were to be changed anyway.
Stugill
#5 PostAuthor: Stugill » Fri Oct 11, 2024 7:53 am
Cheers.
I'll give it a go.
Stu
Stugill
#6 PostAuthor: Stugill » Mon Oct 14, 2024 7:51 am
Good morning.
An update, all good.
I've managed to remove it all with a combination of all the advice and I found that the collar had been damaged at sometime in it's past, hence hunting one down.
Stu
Users browsing this forum: Bing [Bot] and 46 guests
