Z1000J / Z1000 LTD 1981/82 Models. Wiring Harness ?
Foxfix
#1 PostAuthor: Foxfix » Fri Oct 11, 2024 9:33 am
ONLY refrering to Z1000J / Z1000 LTD 1981/82 Models (not earlier kickstart models).
Can anyone please confirm if the main wiring harness should come out of the front of the frame above the horns and out infront of the bottom fork yolke and up into the headlight.............or out of the front of the frame above the horns and directly up into the headlight, BEHIND the lower yolke ?
Looking at images of the above bikes on the web, I can see both routes for the harness have been used, but I need to know what is the correct factory route for the harness ?
Thank you
Re: Z1000J / Z1000 LTD 1981/82 Models. Wiring Harness ?
#2 PostAuthor: warren3200gt » Fri Oct 11, 2024 11:41 am
#3 PostAuthor: Z1streetfighter71 » Fri Oct 11, 2024 11:47 am
warren3200gt wrote:Pictures in here should tell you.
https://www.dropbox.com/scl/fi/de69cd2v ... j2g7i&dl=0
Thanks for that Warren, ill be needing it too soon.
Foxfix
#4 PostAuthor: Foxfix » Fri Oct 11, 2024 12:44 pm
That a great help thank you and has answered my question !
Thanks again
