Mikuni 26mm carbs
James
Mikuni 26mm carbs
#1 PostAuthor: James » Mon Oct 21, 2024 12:21 pm
26mm mikuni's in need of repair,the throttle return spring is missing,damage to air screw no4 carb and the choke lever is broke,easy fix or ideal as spares,no gunge etc in float bowls,but will need to be checked over and cleaned.£120.00 can post 48hr tracked within uk.£10.00 NO LONGER AVAILABLE
Return to “For Sale”
