Z900 carbs,will need checked over as they have sat for a
while,they look clean inside with no major signs of dirt or gunge,
Id no is z12 00. Collect from co Antrim or can post 48hr parcel force.£220.00 posted within the uk.also have a set of 26mm carbs for spares.
Z900 carbs
Z900 carbs
Re: Z900 carbs
That's a decent price for a used set needing work.
Note that the plated support plate is missing.
