turn signal help needed
GregZ
#1 PostAuthor: GregZ » Thu Jun 05, 2008 1:00 am
My left blinkers work fine. My right blinkers not working. If I remove my headlight bucket and switch on my right turn blinkers they work fine. As soon I I replace my headlight bucket My right sides do not work ..Help.
cheers gregz
Z1
1965 Corvette
Dark Skies
#2 PostAuthor: Dark Skies » Thu Jun 05, 2008 1:19 am
What happens if you wiggle the associated right hand indicator wires with the bucket removed? Obviously you've only a partial connection somewhere - worsened when everything is scrunched up to accomodate the space taken up by the headlamp. It's either a partially broken wire or a dodgy male / female bullet connector - partially corroded perhaps?
KZ1000-M1 CSR
GregZ
#3 PostAuthor: GregZ » Sat Jun 07, 2008 8:00 pm
Still have not figured out what is wrong. I checked all the plug/wires and right blinker works fine. With headlight bucket in, blinker works fine. BUT as soon as I tighten the headlight bucket bolts the turn blinker stops working. Mind bender??
Z1
1965 Corvette
PJones
#4 PostAuthor: PJones » Sat Jun 07, 2008 8:18 pm
GregZ wrote:Still have not figured out what is wrong. I checked all the plug/wires and right blinker works fine. With headlight bucket in, blinker works fine. BUT as soon as I tighten the headlight bucket bolts the turn blinker stops working. Mind bender??
Sounds like it could be an earth problem, try connecting another earth wire
WHO NEEDS DRUG'S
Dark Skies
#5 PostAuthor: Dark Skies » Sat Jun 07, 2008 9:41 pm
Do your indicators employ earth (ground, as the Americans have it) leads with a ring that locate under the headlamp side mounts? If so it sounds like it has a partial break that opens when the mounting is tightened. Have a look and see. You could probably just snip off the end connector and put in a new one.
KZ1000-M1 CSR
