The max speed on these is 80mph, is the difference between uk and these mechanical within the clocks or elsewhere?
Cheers Rob
American gpz1100b1 clocks
Z1100R, RD 125LC, Zx7r , Endurance racer, KTM 990rcr
Re: American gpz1100b1 clocks
I believe the front wheel drive unit is the same for the lower mph as it is for the higher mph, so I'd assume the head unit is different.
Even if you can only find a higher kmh head unit you only need to change the face from kmh to mph, as the odometer is a separate unit.
There's a few kmh speedo head units on fleabay (use 25005-1129) although a little pricey.
Will Barber on this site does excellent replacement faces.
Hi, cheers for the info. I already have a replacement face from Will. I was going to fit this one to my b1, but got a uk one as the wiring was slightly different. I will check this one over and put it up for sale as my b1 has gone.
Rob
Rob
