Z1R inner tubes
Peter55
Z1R inner tubes
#1 PostAuthor: Peter55 » Sun Jan 19, 2025 3:19 pm
Hi all
In the parts book and manual it says I should fit inner tubes in the tyres on my Z1R, did they find the wheels are porous or is there another reason for this.
Cheers Peter
Peter55
Re: Z1R inner tubes
#2 PostAuthor: Peter55 » Sun Jan 19, 2025 5:07 pm
Sorry guys just seen that the rear wheel has got two bead clamps so would have to have a tube. I’ll put one in the front as well, I guess this might effect my tyre choice.
Re: Z1R inner tubes
#3 PostAuthor: chrisu » Mon Jan 20, 2025 7:59 am
Not tubeless
Grog
Re: Z1R inner tubes
#4 PostAuthor: Grog » Mon Jan 20, 2025 10:42 am
Hi Peter;
There are different rim profiles on alloy bike wheels - one for tubeless tyres, one for tubed. The Z1R rims are not profiled to hold a tubeless tyre securely, so tubes are needed to keep all that lovely air inside. You don't need a tyre specifically designed for tubes - you can run 'tubeless' tyres quite happily as long as you stick a tube in there as well, so tyre choice isn't an issue. I've run Bridgestone BT45s on mine quite happily for ages; Avon Roadriders also get a good press. Hope this helps!
TTFN Grog
1979 Z1R (mostly - it's been fiddled with a bit)
1977 Z650B1 - I'll get round to putting it back together one day...
Peter55
Re: Z1R inner tubes
#5 PostAuthor: Peter55 » Mon Jan 20, 2025 7:26 pm
Thanks for your replies.
I have gone for Avon Roadriders with tubes, £231 inc postage from Demon Tweeks.
wheelysteve
Re: Z1R inner tubes
#6 PostAuthor: wheelysteve » Mon Jan 20, 2025 9:03 pm
That's what I've got on mine and they work well.
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Sifu
Re: Z1R inner tubes
#7 PostAuthor: Sifu » Fri Jan 24, 2025 1:39 am
I’ve got inner tubes in mine
Sifu
Re: Z1R inner tubes
#8 PostAuthor: Sifu » Fri Jan 24, 2025 1:40 am
That’s a nice z1r wheelysteve
Users browsing this forum: No registered users and 104 guests
