Decals
Mark W
Decals
#1 PostAuthor: Mark W » Fri Mar 14, 2025 8:49 pm
Quick bit of advice from you knowledgeable chaps,when to put the decals on.This is going on a zephyr 1100 ( wire wheels ) choices are after base coat before lacquer,couple of coats of lacquer then apply decals with a couple of lacquer after or completely finish tank then apply
Re: Decals
#2 PostAuthor: warren3200gt » Fri Mar 14, 2025 9:31 pm
Couple of laquer then decals then couple more laquer.
Mark W
Re: Decals
#3 PostAuthor: Mark W » Fri Mar 14, 2025 9:34 pm
Thanks Warren
Re: Decals
#4 PostAuthor: Z1streetfighter71 » Fri Mar 14, 2025 10:22 pm
Dont go crazy with to many clear coats over your base, quick pass and then one "wet coat" if you are using a room temp clear allow at least a week before the final 2 coats over the decals. To many clear coats can muddy the base coat.
