Cush Plate / Wheel spacer
popsA1
#1 PostAuthor: popsA1 » Wed Mar 26, 2025 9:30 pm
Hi Guys,
I’ve just come to install my rear wheel on my Z1000A1 after having both wheels rebuilt only to discover I’ve lost the cush plate spacer. Item 13.
I thought I’d quickly make one, but I need to know the dimension from the sholder to the end.
All the other dimensions I can work out from the bearings. But without that one I stumped.
Can anyone help?
Thanks in advance,
Paul
A2 1979-80. A1 1980-now
KeithZ1R
Re: Cush Plate / Wheel spacer
#2 PostAuthor: KeithZ1R » Sat Mar 29, 2025 9:17 am
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
popsA1
#3 PostAuthor: popsA1 » Sun Mar 30, 2025 8:34 am
Hi Keith,
Thanks for the reply.
Did your spacer come from a set of wire wheels? The 28mm dimension looks a bit long.
I made a spacer with 22mm from shoulder to end and the cush plate was sticking out of the hub to far. I skimmed it down to 18mm and the cush plate / hub look about right. Plus, the wheel now fits in the swinging arm.
I might stick with this and see how it rides.
Paul
