What is recommended for replacing the short hose from fuel tap to carbs? Am I right that it’s 8mm? Mine has perished I think partly due to it being such a tight bend. Is there something a little more flexible ?
Cheers,
Ian.
Fuel hose.
- warren3200gt
Re: Fuel hose.
Re: Fuel hose.
ianali wrote:What is recommended for replacing the short hose from fuel tap to carbs? Am I right that it’s 8mm? Mine has perished I think partly due to it being such a tight bend. Is there something a little more flexible ?
Cheers,
Ian.
Internal diameter is 6.4mm or 1/4 inch. Just a thought, you could fit a flex stainless steel spring over the fuel line to get around the bend.
Re: Fuel hose.
make sure its resistant to ethanol in petrol - I have a notion that it should have a "J" as part of the code number on the side. (If I've got that letter wrong feel free to correct me)
gray
Re: Fuel hose.
If you are not worried by non original looks, go for tygon, it's clear yellow but you have to have wire spring around it as it has a tendency to kink, I use it on mine.
- Mark Tiller
Re: Fuel hose.
APE do fuel filters https://www.amazon.com/Inline-Fuel-Filt ... 192&sr=8-6 which will help.
search for pipe thats OK for E10 fuel
07962421462
