GPz1100B1/B2 shocks - Swap for NEW Ohlins
Big Fluff
#1 PostAuthor: Big Fluff » Tue Apr 15, 2025 10:23 am
After a set of nice original shocks for this B2 and I believe the B1 shocks are the same.
Happy to swap for this set of as new genuine Ohlins which are 375mm eye to eye and are far to tall for this bike.
Thanks in advance.
Re: GPz1100B1/B2 shocks - Swap for NEW Ohlins
#2 PostAuthor: Ultim8pc » Tue Apr 15, 2025 2:29 pm
I note you have the preload wound right down which would increase the ride height..
#3 PostAuthor: Z1streetfighter71 » Tue Apr 15, 2025 3:25 pm
#4 PostAuthor: paul doran » Tue Apr 15, 2025 7:11 pm
Will I have a standard set
Big Fluff
#5 PostAuthor: Big Fluff » Wed Apr 16, 2025 10:09 am
Ultim8pc wrote:I note you have the preload wound right down which would increase the ride height..
That's just what the previous owner had them set to. They are 30mm longer than standard.
#6 PostAuthor: warren3200gt » Wed Apr 16, 2025 12:02 pm
These any good? Need a good clean up as been sitting in the parts bin fo 30 odd years.
Same as the ones in the ebay ad streetfighter linked but a lot closer :lol:
Big Fluff
#7 PostAuthor: Big Fluff » Wed Apr 16, 2025 4:47 pm
Thanks but our good friend Mr Doran might be helping me out first, I'll let you know otherwise.
Kind regards Will.
redzee
#8 PostAuthor: redzee » Wed Apr 16, 2025 4:58 pm
Hi Will,
Do you, or anyone else know if stock shocks can be rebuilt/restored? Is that your plan ?
Eight valve grunt.
#9 PostAuthor: warren3200gt » Wed Apr 16, 2025 6:54 pm
redzee wrote:Hi Will,
Where there's a will there's a way.
Big Fluff
#10 PostAuthor: Big Fluff » Sat Apr 19, 2025 7:51 pm
Yes they should be easy enough, same as most shocks, roll pin securing top spring retainer.
#11 PostAuthor: paul doran » Mon Apr 21, 2025 9:26 am
Will I dug out the shocks unfortunately one of the top eyelets is snapped of so they are scrap
I do have a set of hagons that are very similar but probably not close enough to standard sorry Pal
Lynd44
#12 PostAuthor: Lynd44 » Mon Apr 21, 2025 10:51 am
Theres a set on ebay. D&K's. They need work though :
Stumbled across them while trying to find a stock pair for 1000R2.
https://www.ebay.co.uk/itm/335586574833 ... media=COPY
Z1000R2 ZR1100A1
