Cost of replacing rings and valve stem seals
What is the rough cost of replacing rings and valve stem seals on a 74 z1
- warren3200gt
Re: Cost of replacing rings and valve stem seals
Depends if your doing it or paying to have it done.
Ring set will be about £150 from IMD, Kawasaki oem both kidneys and your left testicle.
Gasket set, vavle stem seals about the same again.
Cylinder honing and labour to do it if your getting a n other to do it anyone's guess.
Then it's a matter of what you fing once it's open. Cam chain guides, cam chain etc, etc. Soon adds up.
Skezza900 wrote:What is the rough cost of replacing rings and valve stem seals on a 74 z1
contact "dogsbolloxofz1b" mike hunisett its the sort of thing that he does for us members
1972 Z1 Euro Spec
1975 Z1B UK Bike
1972 Z1 Euro Spec
1975 Z1B UK Bike
