Z1000a1 starter clutch, drive gear and idler sprocket
scott reid
#1 PostAuthor: scott reid » Mon May 12, 2025 8:42 pm
Hi, I need all the parts in the title. My engine had all of these removed before I bought it, so I need all parts to make the starter able to turn the engine (I have a starter motor).
Thank you
Scott
tightwad
Re: Z1000a1 starter clutch, drive gear and idler sprocket
#2 PostAuthor: tightwad » Tue May 13, 2025 6:40 pm
hi there, this was off my a2, think they were new rollers, £35.00 posted if any good for you
ken
scott reid
#3 PostAuthor: scott reid » Tue May 13, 2025 9:27 pm
Hi Ken, yes please. I've sent you a PM
Scott
KeithZ1R
#4 PostAuthor: KeithZ1R » Wed May 14, 2025 5:53 am
Hi Scott
Pretty sure I’ve got an idler gear somewhere :idea: :?: will check when I’m home
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
tightwad
#5 PostAuthor: tightwad » Wed May 14, 2025 7:06 pm
Hi Scott, not received any pm, got a aftermarket alternator gasket from Zpower available if you haven't already got one, £4.00
scott reid
#6 PostAuthor: scott reid » Sat Jun 07, 2025 8:34 pm
I'm still needing parts. I have the part that the 3 rollers and springs are housed in, but I still need the gear that fits onto that has the case hardened surface for the rollers to grip, and also need the washer that goes between the roller housing and the large gear.
Ta.
Tel
#7 PostAuthor: Tel » Sun Jun 08, 2025 11:57 am
Got one but I'm not sure if its Z1000 or Z1000J....
Anyone know if they're the same?
KeithZ1R
#8 PostAuthor: KeithZ1R » Sun Jun 08, 2025 4:01 pm
21167-003
seems not
Keith
:bop :gom
mistaken.
