Wiring
phil churchett
Crispy, we would need more definition of exactly what you are after. For example, do you still want a kill-switch, horn, headlights? Is it for lightness or efficiency.
One of the problems with modifying the A4 (and Z1000) is that fuse box is down on the battery box, meaning you need to run h/light wires down the back and then back up to the front. Somewhere on this forum member Vduk rewired his Z1000 getting rid of some redundant wiring (hazard lights etc.)
RegardZ.
RegardZ.
