ZRX1200R oil and temp lights.
Strange issue on my REX. The oil and temp warning lights fail to come on when the ignition is switched on when the bike is left overnight. As soon as I have have had it out on a run the issue disappears.
Re: ZRX1200R oil and temp lights.
I had the same fault on one of my ZRX1200R.
Check the block connectors from the clocks.
It was one of the pins had become slightly corroded.
A brief clean and WD40 sorted it.
I'll give that a go. Thanks
