Sea Foam ?
Simonic
Sea Foam ?
#1 PostAuthor: Simonic » Thu Jul 17, 2025 11:41 am
I read in a recent post regarding compression that a product called 'Sea foam' was mentioned for potentially 'sticky' rings.
What is this stuff please and how is it supposed to work.
I will say i have checked all the other obvious things
johnA
Re: Sea Foam ?
#2 PostAuthor: johnA » Thu Jul 17, 2025 7:44 pm
Hello Simon the only sea foam iv'e seen is a fuel stabiliser unless you can pour it down the bores neat and that frees them i think you can buy it on amazon.
Simonic
Re: Sea Foam ?
#3 PostAuthor: Simonic » Fri Jul 18, 2025 5:48 am
Thanks John,
Maybe i've got my wires crossed.
Simon
Re: Sea Foam ?
#4 PostAuthor: warren3200gt » Fri Jul 18, 2025 7:54 am
Simonic
Re: Sea Foam ?
#5 PostAuthor: Simonic » Fri Jul 18, 2025 4:06 pm
warren3200gt wrote:https://seafoam.co.uk/en_gb/products/sea-foam-motor-treatment-oil-fuel-additive/?utm_campaign=UK-Vid
Thank You Sir
Foxfix
Re: Sea Foam ?
#6 PostAuthor: Foxfix » Sat Jul 19, 2025 11:24 am
Marvel Mystery Oil works very very well for releasing piston rings.
I have used it with success on numerous bikes in the past.
marmck
Re: Sea Foam ?
#7 PostAuthor: marmck » Sat Jul 19, 2025 7:07 pm
Foxfix wrote:Marvel Mystery Oil works very very well for releasing piston rings.
How do you use marvel mystery oil to free the sticky rings , thks in advance
Foxfix
Re: Sea Foam ?
#8 PostAuthor: Foxfix » Sun Jul 20, 2025 8:04 am
It depends how "stuck" they are.
Remove spark plugs.
Pour the MMO into each cylinder (use a syringe or pipe with a funnel)
Leave at least 24 hours to soak through.
Alternatively you can add it to petrol if bike is running.
I bought a Z1300 engine that had not been run for years and had no spark plugs fitted.
Needed to get the block off but 2 of the pistons and rings were stuck solid.
I used MMO and after a few days it did the trick.
jonhunt
Re: Sea Foam ?
#9 PostAuthor: jonhunt » Mon Jul 21, 2025 10:29 pm
Tried seafoam in my MR2 did nothing.
Simonic
Re: Sea Foam ?
#10 PostAuthor: Simonic » Tue Jul 22, 2025 11:16 am
jonhunt wrote:Tried seafoam in my MR2 did nothing.
I've had no luck with it either
moizeau
Re: Sea Foam ?
#11 PostAuthor: moizeau » Tue Jul 22, 2025 4:51 pm
Is the reason for this initial post due to low compression or seized piston? Has it been stood inactive for a while?
Does it start?
If it starts and runs ,ride it and once warm wind the revs up from time to time.
When I bought my ST that hadn't run for over 10 years it smoked like buggery and you could smell the oil burning. I ran it. It cleared everything out. It doesn't smoke or smell now.
If you've got a stuck piston I'd stick some diesel, not a lot, down the pot until free. Then once free and starts, run and ride it
Simonic
Re: Sea Foam ?
#12 PostAuthor: Simonic » Wed Jul 23, 2025 9:13 am
moizeau wrote:Is the reason for this initial post due to low compression or seized piston? Has it been stood inactive for a while?
Does it start?
I've got low compression on one cylinder.
The bike was sold to me as a semi runner on the understanding that the carbs needed cleaning as it had stood for a long time. I also had to take the rocker box off as one of the end plugs was leaking so while the carbs were in the ultrasonic bath i did a compression check and found No3 to have 30psi compression. I figure it's either a stuck ring or a bent valve and thought i would try for the stuck ring first. I can say that i have turned the motor over with the rocker box off and can see the valves on No3 opening and closing but i do realize this is not a true indication of wether a valve is bent or not. The sea foam has been in it a couple of days now so i will try another compression test today to see if there is any change
Simonic
Re: Sea Foam ?
#13 PostAuthor: Simonic » Wed Jul 23, 2025 12:47 pm
Further to my previous post on Sea Foam it's been sat in the cylinder for a few day and today i did another compression check and it seems there was a stuck ring and the Sea Foam has freed it off. Compression is now 135 on that cylinder which is an improvement of 100psi. I'll take that
Re: Sea Foam ?
#14 PostAuthor: r3sc » Wed Jul 23, 2025 2:23 pm
That’s a great result!
