Cam cover pipe.
atomic_duck
Cam cover pipe.
#1 PostAuthor: atomic_duck » Fri Jun 13, 2008 5:06 pm
Hi all
Just had the fuel tank off my KZ1000 police, it's a C4 model, and i noticed that on the cam cover at the front of the engine there is a pipe. Although there are two pipe connections on the cam cover, the pipe is only connected at one end. The question is, should the pipe be linking these two connectors or is there something missing. If the pipe does just link these two connectors can someone explain to a beginner the purpose of the pipe.
Many thanks
Paul
#2 PostAuthor: Pigford » Fri Jun 13, 2008 5:37 pm
This will be for the air recycling system to reduce emissions, by introducing air into the exhaust by the ex valve....
I have a spare set of gubbins for a MKII engine that may be of some use, off a CSR custom jobby, although most people just blank the 2 x cam cover breathers off :wink:
atomic_duck
#3 PostAuthor: atomic_duck » Fri Jun 13, 2008 5:53 pm
Now i am totally confused :( which is not difficult for me. I cannot find any reference to this pipe in the Clymers manual, are you telling me that this pipe and one from the other connector should be connected to something that i have missing. If so i want the missing bits :D . There is a polished dome like thing on top of the engine behind the carbs that has a pipe sting from it, is this something to do with it. Sorry for sounding like a total thicko, buts that what i am when it comes to this bike :oops: .
#4 PostAuthor: Pigford » Fri Jun 13, 2008 6:07 pm
:mor
Do you mean the covers either end at the top of the cam covers :?:
atomic_duck
#5 PostAuthor: atomic_duck » Fri Jun 13, 2008 6:42 pm
The offending pipe.
And
Should this pipe be connected to anything or just free to air
Sorry if these are basic questions but only had the bike 2 weeks and it is my first Kawasaki, so i have a lot to learn.
#6 PostAuthor: Pigford » Fri Jun 13, 2008 6:48 pm
Picture (photo's) paint a 1000 words :lol:
Last photo is the crankcase breather and usually has a pipe that is connected to the air box to recycle the ..err... crankcase fumes back into the engine via the carbs, which also helps to keep the carb slides lubricated.
The cam take offs should be connected to a system of pipes which I happen to have spare....
PM you address to me & I can post 'em to you, for cost of postage... I'll also include a photocopy of the relevant pagesd from the Clymer manual - if I can find it :wink:
atomic_duck
#7 PostAuthor: atomic_duck » Fri Jun 13, 2008 7:00 pm
Many thanks for the replys, and a PM has been sent.
I presume the crankcase breather will be ok vented to free space as the bike at the moment has pods on the carbs as opposed to the proper air filter box (another part i need to find). I want to try and get the bike back to as standard as i can, so expect lots of dumb questions from me :lol:
london calling
#8 PostAuthor: london calling » Fri Jun 13, 2008 7:02 pm
Atomic (Toilet) Duck,you'd probably be better with a non US cam cover without emission control fitted and maybe carbs re-jetted to improve performance,etc as emission controls usually restrict the motor :wink:
Jack
#9 PostAuthor: Pigford » Fri Jun 13, 2008 7:13 pm
Atomic Duck.....
As you've got pod filters, fitted, the 'smog' device pipe stuff is no good, coz as jack AVON Calling says, the emmission control stuff does restrict the engine and most people blank off or block the spigots on the cam cover.
The crankcase breather can just vent to atmosphere, no probs.
Also, I've just been out in the garage and can't find the gubbins :oops:
Got a feeling I dumped the stuff, or may have given it to Simon G when I sold the bike to him :?? SORRY :oops:
atomic_duck
#10 PostAuthor: atomic_duck » Fri Jun 13, 2008 7:14 pm
lol
Ok, I am totally thick here but i am willing to learn. So these pipes can upset the running of the bike ?. I ask this because i do get a bit of blowback via the air filters, mainly when cold. The bike had stood for 2 years until i purchased it, the shop got it running and did a MOT but there are a few niggly problems and i need to sort the electrics out. I use the bike daily, but only short runs and just want to do the importent bits first.
#11 PostAuthor: Pigford » Fri Jun 13, 2008 7:37 pm
The reason the pipes are not connected is that the previous owner had the pods fitted and as the std airbox has been removed, the crankcase & cam cover breather system is now redundant. :evil:
The carbs need tuning to run with pod filters, as they allow more air flow, and need more fuel to compensate, or the engine will run lean (may cause misfire when cold) and could damage engine. :shock:
Usually the main jets need increasing. It'll be wise to check to see what size are fitted. Check in your clymer manual, I think std jets are about 115 so try 130's to start with :?:
You can always do a 'search' on the forum, but usually much easier to post a new thread for advice from someone who's done one of these.
atomic_duck
#12 PostAuthor: atomic_duck » Fri Jun 13, 2008 7:43 pm
Thanks for that Pigford. A lot more reading i think. I will blank of the two cam breathers for now and will get the carb settings looked at. thanks for all the advice.
Pasc
#13 PostAuthor: Pasc » Sat Jun 14, 2008 8:40 am
I think Debbens do the cam cover blanking plates.
Dark Skies
#14 PostAuthor: Dark Skies » Wed Jun 18, 2008 10:36 pm
atomic_duck wrote:Many thanks for the replys, and a PM has been sent.
This is what it all looks like when present and correct:
If your bike is on this list then it's the same setup as my KZ1000 CSR
Part # = 11010-1142
Part Description = AIR FILTER ASSEMBLY
Model Count = 17
KZ1000-P10 91 1000 POLICE 1000 POLICE
KZ1000-P11 92 1000 POLICE 1000 POLICE
KZ1000-P12 93 1000 POLICE 1000 POLICE
KZ1000-P13 94 1000 POLICE 1000 POLICE
KZ1000-P14 95 1000 POLICE 1000 POLICE
KZ1000-P15 96 1000 POLICE 1000 POLICE
KZ1000-P16 97 1000 POLICE 1000 POLICE
KZ1000-P17 98 1000 POLICE 1000 POLICE
KZ1000-P18 99 1000 POLICE 1000 POLICE
KZ1000-P4 85 1000 POLICE 1000 POLICE
KZ1000-P5 86 1000 POLICE 1000 POLICE
KZ1000-P6 87 1000 POLICE 1000 POLICE
KZ1000-P7 88 1000 POLICE 1000 POLICE
KZ1000-P8 89 1000 POLICE 1000 POLICE
KZ1000-P9 90 1000 POLICE 1000 POLICE
KZ1000-R1 82 1000 KZ1000 EDDIE LAWSON REPLICA ELR REPLICA
KZ1000-R2 83 1000 KZ1000 EDDIE LAWSON REPLICA ELR REPLICA
It just so happens that I've removed all this stuff from my bike to fit Pods and a dyna kit.
KZ1000-M1 CSR
atomic_duck
#15 PostAuthor: atomic_duck » Thu Jun 19, 2008 5:56 am
Thanks for the pic, now i know what i need. My bike is a 1981 C4 model and being new to these bikes, i am not sure if that would be compatible. If you are selling that kit would you PM me a price.
Paul
Users browsing this forum: Jerry, r3sc and 31 guests
