Switch gear
Ed Z1-R
Switch gear
#1 PostAuthor: Ed Z1-R » Fri Jun 13, 2008 10:49 pm
Ok chaps i require the bottom portion of the Left hand switch gear that incorporates the HAZARD light switch not worried about switches,but need the cable clamp and it must be the type where the cables exit(not into but) along the handlebars. Thanx in advance.
:ed
#2 PostAuthor: Pigford » Sat Jun 14, 2008 8:57 am
Ed, if you got a good (into the handlebar) switch, it don't take much to convert it to an outside the handlebar one, with a DREMEL :wink:
Thats what I did with mine :oops:
Ed Z1-R
#3 PostAuthor: Ed Z1-R » Wed Jan 07, 2009 9:23 am
OK Kiddies im still after this said component
W.H.Y. :?:
:ed
tlc
#4 PostAuthor: tlc » Wed Jan 07, 2009 12:39 pm
I`ve got one that someone has already dremmeled !
bakey
#5 PostAuthor: bakey » Wed Jan 07, 2009 1:07 pm
what does W.H.Y stand for?
sorry about the thread but ive always wondered
''Who's motorcycle is this?''
mick znone
#6 PostAuthor: mick znone » Wed Jan 07, 2009 1:20 pm
ok bakey,why=[what have you]. just like wdy used to equal [why dont you] great program that.
tlc
#7 PostAuthor: tlc » Wed Jan 07, 2009 1:51 pm
Or WTF
#8 PostAuthor: Pigford » Wed Jan 07, 2009 4:36 pm
W O T (Wide Open Throttle) :wink:
ted1r
W.O.T
#9 PostAuthor: ted1r » Wed Jan 07, 2009 6:41 pm
CAN YOU HANG ON THAT FAST :?:
Re: W.O.T
#10 PostAuthor: paul doran » Wed Jan 07, 2009 9:11 pm
ted1r wrote:CAN YOU HANG ON THAT FAST :?:
Ted in Piglet's case it's WOG
wide open gob
#11 PostAuthor: paul doran » Wed Jan 07, 2009 9:12 pm
back to the original post Ed I may have what you need
I need to check
Ed Z1-R
#12 PostAuthor: Ed Z1-R » Wed Jan 14, 2009 9:45 am
Cheers Paul thats appreciated mate :wink:
compo z1r
ed
#13 PostAuthor: compo z1r » Thu Jan 15, 2009 9:56 pm
ed ive' got left hand switch bottom for z1r :?: pm me and ill' send you pics to see if its right, :lol: :lol:
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
Ed Z1-R
#14 PostAuthor: Ed Z1-R » Wed Jan 21, 2009 9:42 am
Compo the standard Z1-R job unfortunately has the cables passing through the handle bars.
And half (well almost)a house brick on its belly side :green
Ed Z1-R
#15 PostAuthor: Ed Z1-R » Wed Mar 18, 2009 11:36 pm
Ok kiddies have procured the said required bottom casting (many thanx Baz :up )
Now....
All i need is......
The metal clamp that affixes to the bottom casing of the switch gear assembly to keep the wires in place in the groove where they exit the switch gear.
Savvy :idea:
Thanx in advance.
:biggrin
