Greetings all. I've just started to restore my Z1A. It's an American import - in excellent condition APART from the previous owner decided he liked Z1 colours so all paintwork and engine are wrong. Long story told long I've stripped it and have had the engine and carbs vapoured - superb finish. Anyway I started to reassemble the carbs today and discovered it has 17.5 pilot jets whereas I believe it should have 20.0. It ran beautifully before so they are'nt a problem but my question is if I put 20s in what difference will it make and should I stick with the 17.5. It might be an obvious answer but I would like advice please.
Many thanks in advance
1 GOM
Z1A Jetting
- RALPHARAMA
I'm no expert on carburration; do the pilot jets do their bit during a certain rev range (ie air velocity through the venturii) as I always thought or is it related to the level of throttle opening?
Ralph Ferrand
Ralphy,
Yes and Yes...
The pilot jet is only really noticeable at part throttle opening and the carbs rely on pressure differential in the venturi (slide opening) to draw the fuel thru, due to the negative pressure in the venturi
As the slide lifts, the needle then allows the main jet to come into play and provide more fuel as the venturi size increases:
More air needs More fuel
Carb tuning is best done working from full throttle and getting the main jets about right, before messing with needle position (mid throttle position) and finally pilot jets
Yes and Yes...
1GOM
