photos?????
mikey
photos?????
#1 PostAuthor: mikey » Sat Jun 21, 2008 3:14 pm
Ok now its got spoke wheels and a proper front muddy thought id have a go at posting a pic been at this all afternoon wont say how many hours itll be embarasing :oops: and if it dont work computers going out the window :evil:
[IMG]http://i298.photobucket.com/albums/mm279/mykey07-photos/z1.jpg[IMG]
[IMG]http;//i298.photobucket.com/albums/mm279/mykey07-photos/z2.jpg[IMG]
mikey
#2 PostAuthor: mikey » Sat Jun 21, 2008 3:15 pm
Right fcuking pc being drop kicked out the window :evil:
Surfdeneige
#3 PostAuthor: Surfdeneige » Sat Jun 21, 2008 3:26 pm
[img]http;//i298.photobucket.com/albums/mm279/mykey07-photos/z2.jpg[/img]
the second img needs a / like so [img]the%20image[/img] and had you not removed the pictures we would see your bike now
A ken fit like!
mikey
#4 PostAuthor: mikey » Sat Jun 21, 2008 3:31 pm
How did i remove it i just cant grasp how to do it
ash
#5 PostAuthor: ash » Sat Jun 21, 2008 3:38 pm
I,ll even do it to Mikey,
ash
#6 PostAuthor: ash » Sat Jun 21, 2008 3:43 pm
Give um me i,ll make um bigger :
ash
#7 PostAuthor: ash » Sat Jun 21, 2008 4:16 pm
Mikey had a play, but when i enlarge them they get distorted, i,ll have another play
mikey
#8 PostAuthor: mikey » Sat Jun 21, 2008 4:20 pm
Ok mate dont bust a gut over it after all got the real thing sat in me garage :lol:
ash
#9 PostAuthor: ash » Sat Jun 21, 2008 4:23 pm
Very true, and looks great to, :D
RALPHARAMA
#10 PostAuthor: RALPHARAMA » Sat Jun 21, 2008 4:25 pm
Ralph Ferrand
mikey
#11 PostAuthor: mikey » Sat Jun 21, 2008 4:42 pm
Cheers ash lots of fun riding it to
Geoff Meager
#12 PostAuthor: Geoff Meager » Sat Jun 21, 2008 9:22 pm
Mikey me old mate ..you Knob Head what have you done..
Never mind will kiss your shiney head next time we meet .. :shock:
By the way I ment your top head .. :D
mikey
#13 PostAuthor: mikey » Sat Jun 21, 2008 11:33 pm
Fcuk knows geoff but it took me hours to get the pics onto photo bucket then davy doherty got em on the site for me i give up i just cant do it
#14 PostAuthor: Al » Sun Jun 22, 2008 12:55 am
Hold on mikey dont give up. There is a simple tutorial in photobucket for posting piccys. I too spent many many hours on Monday and Tuesday loading simple video cos they have changed stuff about radically in very recent times.
The only challenge is to get the pictures onto photofu*&it and if you can see them on there then so can we.
Make sure you are in the album they have asked for, which will be the one you have opened and called Z pics for example. Click on browse for your pictures. This takes you into a replica of your PC. Find the pictures you want to post and then click ok or save.
When youve done it it will say loading image, encoding.......... and then it will say saving to server.
Untill you have seen both of these two notifications in the information window that you are loading the picture into then you must not do anything else let it make the moves it is automatic.
Go make some tea or have a wander outside or do as i do and go and change the water in the cold towel i have wrapped around my head to keep cool.
Click on save and continue and then the picture will be evident in the window.
If you click on save and continue then that window (loaded image window) closes and the picture then appears in the album window which opens next automatically.
Ten or so minutes may have elapsed and then the pictures will have appeared in a tiny window which is a thumbnail of the contents of your album.
Below the picture is a block of four shortcuts and the bottom one is the one to use for direct posting into chatrooms and the like.
To its' immediate left it say IMG.
The block with the actual adress is partially obscured but no matter you dont need to see it fully. It is slightly yellowy in colour compared to the text on the page.
Hovver the mouse pointer over the partial address that you can see it begins [URL=http
and left mouse click it.
A small yellow notification appears saying COPIED and the address that it has copied it highlights in blue for you. You have now won because when writing you post, simply left click in the post window for this site and select paste. Nothing else to do.
If your using Vista you can keep both Z1OC and photobucket open at the sme time by using two seperate tabs.
If using XP or 95 you just open a new window and have both open simutaneously. I find this helps because you can flit back and forth between the two.
I bet this sounds more confusing than actually doing it. It took me literally days but i am not someone who has ever given up however beaten i am.
P.S. My offer still stands to help with putting the engine back in if you need. See other post about shards of metal in Andy Z1Rs' engine.
This is the link to the tutorial for single image using the old uploader.
http://tutorials.photobucket.com/tutorial_3.html
This for multiple images using old uploader.
http://tutorials.photobucket.com/tutorial_39.html
This one for video clips using old uploader.
http://tutorials.photobucket.com/tutorial_8.html
I tried the beta uploader and it works fine if you need it for video.
It also gives what they call and action preview window.
See post; Meetings and events Wroughton Sunday 15th June
Hope this helps Mikey but in the event that it does not then drop me a pm or e-mail and i can see you through it.
mikey
#15 PostAuthor: mikey » Sun Jun 22, 2008 5:34 am
Thanks zorded ill print this off later and when got time ill give it a go id like to learn how to do it im probably making a mistake thats glaring obvious but cant see it for looking :shock:
