any help would be appreciated
clocks
Hidden mods
Dont know if this is what you mean but i cut four inches off both front springs on mine with an angle grinder and it lowered it quite a bit. I also took the precaution of removing half of the fork oil too and bumping the air pressure to 30 bar. Needed a bit more so fitted a 17inch front wheel and let some air out of the tyre. I put one inch longer back struts on and two inch longer springs on them and turned them up to top notch. This way the overall symetry and layout of the bike remained the same with everything still in its' proper place but gave it that certain something. The French have a saying that covers it but i forget now. Looks like a proper drag bike now, in fact it looks just like Andy Z1r's drag bike, (see other posts) very purposeful and i can get my tiny legs over the seat at long last.
Let me know if you need 'orthographic projection' drawings etc.
- RALPHARAMA
don't feed the troll
Ralph Ferrand
Re: Hidden mods
zorded wrote:Dont know if this is what you mean but i cut four inches off both front springs on mine with an angle grinder and it lowered it quite a bit. I also took the precaution of removing half of the fork oil too and bumping the air pressure to 30 bar. Needed a bit more so fitted a 17inch front wheel and let some air out of the tyre. I put one inch longer back struts on and two inch longer springs on them and turned them up to top notch. This way the overall symetry and layout of the bike remained the same with everything still in its' proper place but gave it that certain something. The French have a saying that covers it but i forget now. Looks like a proper drag bike now, in fact it looks just like Andy Z1r's drag bike, (see other posts) very purposeful and i can get my tiny legs over the seat at long last.
I think I saw your bike featured in Streetfighters recently
- london calling
- london calling
