noisy dyna coils
GregZ
noisy dyna coils
#1 PostAuthor: GregZ » Tue Jun 24, 2008 2:25 am
Just installed dyna coils,wires and the ignition pick up. Zed is running real good. However you can hear the coils,and it is rather loud. At first I thought is was cam chain so I adjusted not once but twice. finally found the tat tat tat niose is the coils. Is this normal sound from coils???
cheers
gregz
Z1
1965 Corvette
rickman CRR
#2 PostAuthor: rickman CRR » Tue Jun 24, 2008 11:20 am
ehmm.....no they shouldnt make a noise. Are they shorting out under the tank?
Steve Cooke
#3 PostAuthor: Steve Cooke » Tue Jun 24, 2008 2:18 pm
Did you insulate the mounting post? as it is extremely close to the terminal and is a likely area to short, although you wouldn't expect the bike to run too well if it was.
#4 PostAuthor: Pigford » Tue Jun 24, 2008 6:12 pm
Money's on them shorting out, and if its that loud its gotta be on the hi-tension side (coil lead output) :shock:
But as Steve say's, check the low tension input ( 2 x screws) coz the lower one is close to the mounting post :!:
#5 PostAuthor: Rich » Tue Jun 24, 2008 6:20 pm
you have tightened the bolts up?
GregZ
#6 PostAuthor: GregZ » Tue Jun 24, 2008 11:31 pm
I put heat shrink on the mount bolts,spacers and after tightning the power screws I siliconed them. I will double check everything.
thanks
Z1
1965 Corvette
GregZ
#7 PostAuthor: GregZ » Wed Jun 25, 2008 1:38 am
I found my problem. The spacers(hardware store) are two thick in diameter. When fitted loose they fit good but when tightning the coils to the frame they seemed to draw in a little bit and just make contact with the screw for the power wire. I replaced them with stock spacers but I had to use some extra washers so coil does not make contact with frame.
No more noise. If you are still running points I would highly recomend the dyna set up. With the denso plugs and the eletronic ign. Zed runs good !
gregz
Z1
1965 Corvette
