Crank
PJones
Crank
#1 PostAuthor: PJones » Mon Jun 30, 2008 6:42 pm
Hi guys eventually I will be building a Z900 to go with the Z1000 (Lily Grace - Depending), however after checking all the boxes, 5 yrs later it looks like there is no crank. There is one on ebay for a Z1000A1 / A2 are they the same??
PJ
WHO NEEDS DRUG'S
phil churchett
#2 PostAuthor: phil churchett » Mon Jun 30, 2008 6:54 pm
Paul, Z Power's parts book lists different part no's for the 900 and 1000.
It is worth calling Dave in the morning to find out exactly what the difference is.
PJones
#3 PostAuthor: PJones » Mon Jun 30, 2008 6:59 pm
phil churchett wrote:Paul, Z Power's parts book lists different part no's for the 900 and 1000.
Cheers Phil
WHO NEEDS DRUG'S
Big Fluff
#4 PostAuthor: Big Fluff » Tue Jul 01, 2008 12:18 pm
The 900 cranks are 'webbed' whereas the Z1000 cranks are full flywheel.
If you're using standard height pistons you're ok with either.
If like me you're using taller 'turbo' pistons then you have to use the webbed crank to stop the pistons smacking into the crank as you approach BDC. :shock:
Users browsing this forum: No registered users and 90 guests
