z650 alloy wheels CSR?
christiemk2
#1 PostAuthor: christiemk2 » Tue Jul 08, 2008 10:14 pm
recently bought a set of spoked alloy wheels off Ebay described as from a 650CSR. Looks about right going by latest edition of C&MM feat.this bike.
The rear 16"/drum looks ok to fit with a z1000 cush drive and a tweak of spacers.
The front- not so easy. the hollow for the spindle is a good bit narrower than the std 650 item off my F model with twin discs.
Question- Is it just a case of fitting bearings to suit the larger spindle or is the whole hub u/s?
Didnt pay much for them and dont want to pay too much more to try it all out.
Should I be looking for an old set of std spokies and save myself the hassle. Can the std spoke F take twin discs?
Anyone got any up for grabs?
Quite fancy the current look of the black rim/ss spoke supermotos/h*rleys for my old nail
Kenny
#2 PostAuthor: Rich » Wed Jul 09, 2008 10:53 am
Check to make sure that you can get bearings of the size you want. If you can then you just need a centre spacer made or the existing one bored out if it will take it.
Users browsing this forum: kev edwards and 54 guests
