Dyna S Ignition on ELR
martinz1000r
#1 PostAuthor: martinz1000r » Fri Jul 11, 2008 2:09 pm
Is this a worthwhile investment on my 1984 Z1000R? As it slowly comes back together and I have a little cash is it worth splashing out?
Recommendations welcomed!
floydsz1
#2 PostAuthor: floydsz1 » Fri Jul 11, 2008 2:50 pm
Hi Martin,
I Always fit one to my bikes Z1 Z1A and A4. and as they all start and run better i find it a good investment. I buy mine from Jeff at z1 enterprises due to the exchange rate, plus they only take 15 mins to fit.
peter.
#3 PostAuthor: Rich » Fri Jul 11, 2008 4:48 pm
What's wrong with your std ignition?
RALPHARAMA
#4 PostAuthor: RALPHARAMA » Fri Jul 11, 2008 10:24 pm
Z1 Enterprises seem to want about half the cost of buying one in the UK. I have to say if I get another Zed the first thing I'll do is pop Dyna S on it. The dearer ones really aren't worth the extra wedge and are quite temperamental.
Go for it mate! They're Gerrrrrrrrreat! -- Sadly I'm not on commission :(
Ralph Ferrand
#5 PostAuthor: chrisNI » Sat Jul 12, 2008 12:18 am
I think what Rich means is the electronic ignition on the 1000R is pretty reliable - the Dyna S is a shitload better than points but if the Kwak ignition is working why change it.
martinz1000r
#6 PostAuthor: martinz1000r » Sun Jul 13, 2008 6:28 pm
Thanks to Rich and ChrisNI! There is nothing wrong with the standard ignition hence the question - would I gain anything?
From what you both say then the answer is no and I'll keep the cash a bit longer until the standard packs up!
#7 PostAuthor: Rich » Mon Jul 14, 2008 5:31 pm
You would gain a bit if you put the coils on, but you would probably not notice with a std engine and loom in good condition. The ignition unit it is reliable and certainly on a par with the Dyna S unit.
