disc brake squeal
dave cullen
disc brake squeal
#1 PostAuthor: dave cullen » Sun Jul 13, 2008 8:35 pm
whats the first thing to look for on an old Z that has
(a) brake squeal on braking and
(b) squeaking from front wheel?
the pads dont seem to be binding or anything and braking is good;
any advice appreciated
Tall_order
#2 PostAuthor: Tall_order » Sun Jul 13, 2008 9:02 pm
Copper slip on the back of the pads?
000zeds
#3 PostAuthor: 000zeds » Sun Jul 13, 2008 9:05 pm
Pack Copper Grease behind floating brake pad and smear a little around edges. Also make sure caliper is sliding properly on shafts.
Zeds-R-Us
Geoff Meager
#4 PostAuthor: Geoff Meager » Mon Jul 14, 2008 8:17 am
Like they have said .... keep it well greased with copperslip ... because it don't take long to build up with brake dust ( more with drilled disc )
Dark Skies
#5 PostAuthor: Dark Skies » Tue Jul 15, 2008 5:33 pm
The pads might be glazed. You could try roughing them up a bit with coarse sandpaper laid on a flat surface (steel sheet / plate glass).
KZ1000-M1 CSR
ROZZER
#6 PostAuthor: ROZZER » Sat Jul 19, 2008 8:12 am
Have you got the metal shims in? My Z1b squeeled like a stuck pig until I sourced the shim (missing from my caliper) with coppaslip now squeek free.
AKA John Roscoe. PUM #028
1975 Z1B, 1980 Yamaha 350LC
