Engine swop?
Keefleaf
Engine swop?
#1 PostAuthor: Keefleaf » Wed Jul 23, 2008 9:07 pm
Hi,has anyone put a Gpz 1100,[j motor} in earlier frame,78 Z!000?
Can I use any of the original mounts from either donor bikes?
I know Z1 has two mounts,back-one front.The Gpz,two front one back.
Do I have to make all brackets / chain in line?
Where`s Jack?
london calling
#2 PostAuthor: london calling » Thu Jul 24, 2008 4:33 am
I'm here :twisted:
I've never done this Keith,so I can't help you out.
I'm pretty sure there's quite a few such modded bikes on the German websites listed in the links section,have a butchers my old china :wink:
Jack
FER
Auld Heedyun
#3 PostAuthor: FER » Thu Jul 24, 2008 10:47 am
Top rear engine mount is in the same place . Will need spacers made Gpz/J mount is a wee bit different . Top front engine mount shouldn't be too far away but will need new bracket/spacer as rubber mounts are used on J motor , bottom front mount needs tube and mountings welded to frame downtubes . Easy peasy .
fer
shrekward
#4 PostAuthor: shrekward » Thu Jul 24, 2008 3:57 pm
Keefleaf
#5 PostAuthor: Keefleaf » Thu Jul 24, 2008 10:54 pm
Cheers guys,will check it out and let you know.Hope to ride it to1stSouth
West rally in Sept`,fingers crossed.I will try to post some pictures as and when it happens.
#6 PostAuthor: paul doran » Thu Jul 24, 2008 10:58 pm
shrekward wrote:Image
beautiful
Users browsing this forum: kev edwards and 58 guests
