What thie hell is this
fredswat
#1 PostAuthor: fredswat » Sun Jul 27, 2008 12:43 pm
Just started the electrical part of my Z1B rebuild and have found this see picture I can't remember where it goes . I don't have a clue what it does either . Any one of you experts know
Keefleaf
#2 PostAuthor: Keefleaf » Sun Jul 27, 2008 12:49 pm
It` a piece of crap! It is something to do with the headlight.Most people ditched it ,then your headlight gets brighter.If you want 100% original
fit it to the loom under petrol tank.I expect someone could/will give you a
more technical/accurate answer but I think that`s basically it.
GEZ635
its a resistor
#3 PostAuthor: GEZ635 » Sun Jul 27, 2008 2:14 pm
should have a metal bracket with it that fits around it with a bolt running through the middle. The bracket fits directly under one of the coils and is held in place by the same nuts that are used to hold the coils in place. The bracket tend to crack so a lot of people discard them and leave them stuffed in the loom. i would keep it if you are using a standard rectifer and regulator as we all know the charging system is not great!. If you are replacing them with a combined ect/reg unit I guess it is not so important. Previuos thread was right about it being part of the head light system.
Bracket part no is 32122-034
Gez
RALPHARAMA
#4 PostAuthor: RALPHARAMA » Sun Jul 27, 2008 5:25 pm
It's a wire wound ballast resistor. I did investigate it's purpose when rewiring my Zed and then figured it was best put in the not required box in teh hope that it will be worth lots of money one day :lol:
I have a feeling it might have been something to do with one Kawasaki's many efforts to stop the bikes blowing headlight bulbs, but it just made 'em dim.
The Old Gurl has done well over 3K miles since resto and all is working well and I have yet to blow a headlight bulb, despite keeping it on at all times :D
So bottom line - store it carefully in case it because valuable one day :wink: :wink:
Ralph Ferrand
fredswat
What the Hell is this?
#5 PostAuthor: fredswat » Mon Jul 28, 2008 8:14 pm
Thanks for the help I will probably try it with and without to see if makes a difference when I get to that stage. I dont think I have a bracket for it to fit to though
Users browsing this forum: Bing [Bot] and 59 guests
