530 chain conversion 18x45
GregZ
#1 PostAuthor: GregZ » Sun Aug 10, 2008 5:51 pm
Went shopping for zed parts today and came home with this. I needed a new chain on the 73 so this looked tasty. Complete 530 conversion DID chain. Denco alloy 45 tooth rear and 18 front. Not worried about correct restoration we want it to run good. Is this a good ratio combo ??Found out the 73 has a 1045 motor 150psi in each cyl and denco clutch plates.
So will zed run good with this sprocket set up?
gregz
Z1
1965 Corvette
