newtronic ignition black box
Z1B Alan
#1 PostAuthor: Z1B Alan » Sat Aug 30, 2008 6:43 pm
Out on the bike the other day when cylinders 1+4 packed up :oops:
limped into work had the coil tested to find zero resistance on said coil.
however also smelt hot electrical smell from the ignition "black box" so my question is after i change the coil if the black box is u/s dose anybody have one for sale .et.c.
p.s the bike runs on cylinders 2/3 so dose this indicate the control unit is ok :?: any ideas welcome.
regards
alan
Big Fluff
#2 PostAuthor: Big Fluff » Sun Aug 31, 2008 9:20 am
Alan
The amplifiers within the black box often go tits up mate, it's not worth risking getting another in my mind.
The simple answer, and permenant solution, is to fit a Dyna S ignition system. No black box, 100% reliable, and you can use standard or high output coils. Fit, forget & enjoy :up
000zeds
#3 PostAuthor: 000zeds » Sun Aug 31, 2008 3:05 pm
Big Fluff is 100% right . Did the same myself , got rid of Newtronics on Z1 and Boyer on Z2 .
Zeds-R-Us
ROZZER
#4 PostAuthor: ROZZER » Sun Aug 31, 2008 7:08 pm
The lads are right our kid, yer black box is Donald ducked. Get Dyna S with new coils, job sorted, dead simple no fancy electronics. Time to break out the VISA card mate. (now Fer is bound to reply and say fit Dyna 2000).
AKA John Roscoe. PUM #028
1975 Z1B, 1980 Yamaha 350LC
#5 PostAuthor: Pigford » Sun Aug 31, 2008 7:23 pm
As JR says...... Dyna S is the best bet... the 2000 is overkill & can play up... :shock:
http://www.z1ownersclub.co.uk/forum/vie ... php?t=5114
Ed Z1-R
#6 PostAuthor: Ed Z1-R » Mon Sep 01, 2008 8:10 pm
Dont like Newtronic from previous experience. :twisted:
Got Boyer fitted to the ZeD 2000+ miles and its still going strong :wink:
