advice on petrol please
jake
#1 PostAuthor: jake » Wed Sep 03, 2008 7:27 pm
have a z1000 motor with debben 'super gas' z900 head fitted,1mm o/s valves,megacycle cams.was told only to run on leaded fuel, which when i got bike was no problem, however during bikes overlong hibernation lead is now a distant memory. would you advise additive or is unleaded ok??
#2 PostAuthor: Pigford » Wed Sep 03, 2008 7:40 pm
Best give Ray or Steve a shout.... or PM him - Debben1
Millers do a good lead replacement (not cheap tho)... :shock:
Depending on valve seat material, you could get away with retarding the ignition a few degrees if pinking :wink:
#3 PostAuthor: Pigford » Wed Sep 03, 2008 7:40 pm
KWACKERZ1
Bayford thrust do 4 star
#4 PostAuthor: KWACKERZ1 » Wed Sep 03, 2008 8:29 pm
http://www.leadedpetrol.co.uk/list.htm
You can get leaded petrol from a company called Bayford thrust they distribute it to UK petrol stations, the list you can find on their website.(above)
I use it occasionally when I am planning on leaving the bikes standing for a while as it does not degrade as much as unleaded. You can also use millers vsp additive which is a good additive.
Hope this helps.
GUYZED
#5 PostAuthor: GUYZED » Wed Sep 03, 2008 8:44 pm
You can always put the lead back into the petrol by the way of a fuelcat.
Which is just balls of lead inclosed in a mesh that you just pop into your tank. :D
#449
Z1000A2 Z650B1
debben1
#6 PostAuthor: debben1 » Wed Sep 03, 2008 11:49 pm
Hello Jake, Regular fuel will be ok, check plugs after a 100 miles or so, Regards, Steve
Dark Skies
#7 PostAuthor: Dark Skies » Thu Sep 04, 2008 6:31 am
GUYZED wrote:You can always put the lead back into the petrol by the way of a fuelcat.
Which is just balls.
There, all fixed. No charge. :)
http://pigeonsnest.co.uk/stuff/crapstuff/fuelcat.html
KZ1000-M1 CSR
jake
#8 PostAuthor: jake » Thu Sep 04, 2008 9:02 am
thanks all,thats me sorted !!
02GF74
#9 PostAuthor: 02GF74 » Wed Sep 17, 2008 7:16 am
from the link, fuelcat is not quite the same as the lead pellet.
there is another product(s) thatis supposed to replace the lead but again it is load of BS - the lead in petrol is some compound of lead and putting for example lead shot in the tank, is gonna do nowt as the lead isnlt going to dissolve.
the head should be able to take unleaded as being aluminium, must have inserted and presumable hardened ones that take unleaded - the issue may be with pinking though, retarding igniton is one way that may prevent that.
