HELP! Z1000H
ARCHIE
HELP! Z1000H
#1 PostAuthor: ARCHIE » Sun Sep 07, 2008 8:26 pm
Is there anyone who has a z1000H and has had problems removing the cylinder head? I've removed all the domed nuts and washers and managed to get to lift about 2mm most ot the way round, but it's stuck at the front. I've tried wooden wedges and even a flatened bar on the thicker lugs and soaked it with releasing agent. All the studs are loose and the locating pins are free, am i missing something?
Thanks Archie :?:
debben1
#2 PostAuthor: debben1 » Sun Sep 07, 2008 11:11 pm
Hello Archie, I am guessing that you have also removed the 2 6mm bolts from the ends, Its not the exhaust studs catching on anything or the cam chain guide wheels getting hooked up? Regards, Steve
ARCHIE
#3 PostAuthor: ARCHIE » Tue Sep 09, 2008 6:09 pm
Thanks for the reply Steve, I've finally managed to shift the bugger. It took five days of swearing and sweating but it lifted, it was the front two studs that were corroded.
Thanks Archie
#4 PostAuthor: paul doran » Tue Sep 09, 2008 11:08 pm
Archie any pictures of the H
ARCHIE
#5 PostAuthor: ARCHIE » Wed Sep 10, 2008 5:38 pm
Yes mate i will post them soon.
Archie
ARCHIE
Z1000H PICS
#6 PostAuthor: ARCHIE » Wed Sep 10, 2008 6:03 pm
Hopefully these came out
Archie
ARCHIE
#7 PostAuthor: ARCHIE » Wed Sep 10, 2008 6:09 pm
