Carbs
Taffus
Carbs
#1 PostAuthor: Taffus » Sat Sep 13, 2008 5:16 pm
Just checked the jetting on my carbs (GPz1100 B1 conversion) as I have a slight flat spot at 5.5k
and i found the main set to 144 but the pilot system has ben blanked off. Anyone seen this before?
Also I am running a harris pipe, is the main jet size ok or should I goi bigger?
big green bus
#2 PostAuthor: big green bus » Sat Sep 13, 2008 7:04 pm
your main jet is far to big you need a 130 and the rubber bung is correct on the other jet
