circuit diagram for voltage regulator?
02GF74
#1 PostAuthor: 02GF74 » Tue Sep 16, 2008 8:42 am
Bit of a long shot I know but does anyone have circuit regulator for the Z1000 voltage regulator?
Haynes manual shows one that has 3 triacs, zener diode and 2 resistors but I a not convinced it is correct (but I need to figure out how exacty it works).
Or a similar circuit? (I plan to fit inside the origian case, easier said than done perhaps...)
I do have a commbined rectifier/regulator unit but do not want to chop up the loom just yet, especially since I do not know if the unit is working.
Taffus
#2 PostAuthor: Taffus » Tue Sep 16, 2008 11:42 am
out of the Haynes US manual.......
02GF74
#3 PostAuthor: 02GF74 » Tue Sep 16, 2008 2:18 pm
Brilliant - thanks!
thas is identical to the Haynes manual.
I don't think it is correct as since all the thyristor gates are connectged together, then they are on, then Th1 is shorting t he winding to ground - that cannot be right.
Taffus
#4 PostAuthor: Taffus » Tue Sep 16, 2008 2:52 pm
KZ1100 cct I think it is correct that the Thyristors short to earth.
Steve Cooke
Regulator
#5 PostAuthor: Steve Cooke » Wed Sep 17, 2008 7:08 pm
Hope these help from the kawasaki manual Z1000 A1/A2.
[img][img]http://i162.photobucket.com/albums/t263/stevencooke/DSC04691.jpg[/img]
[/img]Image
[img][img]http://i162.photobucket.com/albums/t263/stevencooke/DSC04692.jpg[/img]
[/img]Image
Steve Cooke
Regulator
#6 PostAuthor: Steve Cooke » Wed Sep 17, 2008 7:10 pm
Missed one.
[img][img]http://i162.photobucket.com/albums/t263/stevencooke/DSC04686-1.jpg[/img][/img]
02GF74
#7 PostAuthor: 02GF74 » Thu Sep 18, 2008 8:36 am
many thanks for that (I wish I could say it is crystal clear especailly since the descritpion and arrows for t he current through t he diodes is incorrect; current would flow in oposite direction, hmmmm.... )
