z1 sticker location
GEZ635
z1 sticker location
#1 PostAuthor: GEZ635 » Sat Sep 20, 2008 8:18 am
Has anyone got pictures of the exact under seat sticker location for a us z1?...not a uk z1 as I have those. I have seen various pictures but need someone with exact information if possible. Thanks boys.
Gez
Garn 1
#2 PostAuthor: Garn 1 » Sat Sep 20, 2008 11:07 am
GeZ635, I can probably get you some under-seat pictures from a friend that has a few low milage US Z1's. However, I think you may find that the positioning of a lot of the transfers were left up to the particular agent.
I laughed when I saw an early Z1 with a brake fluid transfer mounted on the side-cover near the chain oiler. Until I later saw another Z1 with that particular transfer located in the same place. That agent may have thought that the chain oil tank held hydraulic oil.
Something I may help with, is that the transfer showing the route for the battery plastic overflow tube is not present on the seat of a Z1. Also, that the wording for replacemnt chain due to excessive wear was changed (That's the white transfer only on Z1's attached to a leg of the tail piece).
I have also heard that some Z1's did not have any transfers on the inner guard. I have not seen one without any!
RegardZ.
Davy Doherty
#3 PostAuthor: Davy Doherty » Sun Sep 21, 2008 4:07 pm
GEZ635
stickers
#4 PostAuthor: GEZ635 » Sun Sep 21, 2008 6:24 pm
Thanks Davy, I had seen it before and forgot about it. Just what I needed so thanks for the info.
Gez
Davy Doherty
#5 PostAuthor: Davy Doherty » Sun Sep 21, 2008 7:37 pm
Garn 1 wrote:.
RegardZ.
Garn my early Z1 also has that sticker on the side cover..and i've seen a few the same!!
