Are there any other petrol taps that will fit a Z900? I need a single outlet to fit 28mm smooth bore carbs with a single center inlet pipe. I have been told that Late model Harleys might fit, somebody must have had the same problem.
regards
Petrol Tap replacement ?????
I recently fitted a new Harley tap single outlet to my 900 with standard carbs. It looks quite good; but I havent done many miles on it. The flow seems quite good. Not sure about bigger carbs tho.Worth a shot at $25 .
Mine leaked in the OFF position on day one: i`ve since turned the seal and all appears to be well.
Tommy
Tommy
