bearings
bearings
i have removed swingarm bearings and made it narrower now the problem is i don't seem to be able to find some bearings with a outside diameter of 33mm and inside diameter off 16mm does any one know if they are avalable in this size? i have found 35mm x 16mm.
33 OD!?!?!?
look here: http://simplybearings.co.uk/shop/deep_g ... choice.php
OD goes from 32 to 35. you may have imperial or a more likley an unusual size.
16 x 35 looks like the only option - bugger!
